Re-installing my Intake to finish off Head Project question..
Old Jun 29, 2003 | 07:43 PM
Smokn '94 Z's Avatar
Question Re-installing my Intake to finish off Head Project question..
I am going to install my Intake tonight or tomorrow. I have done this before & I used a ton of RTV. I used it on the back & front & up the sides of the heads a bit, but even took it one step further & put it on the intake gaskets to help ensure no leakage. My question to you's, is that extra RTV I put on the Intake gaskets overkill & if so I should have no leaking problems with just the Fel-Pro intake gaskets right?
Thanks in advance..
Old Jun 29, 2003 | 07:49 PM
anaik's Avatar
Too much RTV will get sqeezed out and end up in the oil pan, then will get sucked up against the oil pump pickup screen, causing a partial blockage. Speaking from experience.
LS1_03's Avatar
You should be fine just doing the front and back, and going just a lil bit up on the gaskets. I don't think you have to cover the gaskets. But, if you don't feel too good about not doing that, then spread the **** everywhere.
Old Jun 29, 2003 | 07:50 PM
FastZinTennessee's Avatar
This is all you need
http://images.cardomain.com/member_i...77_38_full.jpg
John
Old Jun 29, 2003 | 08:11 PM
AENIMA95z28's Avatar
I read you were supposed to put a thin bead of RTV on the top and bottom of the intake gasket. I bought a can of spray on gasket and figured it would just be easier to spray a think layer on the top and the bottom of the intake gaskets. Is this a good idea ?
Oh i dont need hi temp RTV correct ?
Old Jun 29, 2003 | 08:16 PM
Mikey97Z's Avatar
But when you tighten down the intake it squishes the RTV out a little. You don't want ant of that peeking into the intake ports and disturbing the airflow.
Thousands of intakes are running just great without RTV on the gaskets.
Old Jun 29, 2003 | 08:18 PM
Really ? so NO rtv on the gaskets period ?
Old Jun 29, 2003 | 08:26 PM
anaik's Avatar
The first time I removed my intake, there was no sealant put on at the factory on the gaskets.
Old Jun 29, 2003 | 08:55 PM
Thumbs up
Thanks once again guys. You guys have made me a pretty good wrencher on this LT1!!
Old Jun 29, 2003 | 09:39 PM
anaik's Avatar
I should add that when I reinstalled, I used a dab here and there to keep the gaskets from sliding around when I put the intake back on.
Old Jun 30, 2003 | 08:25 AM
scoobysnax83's Avatar
that sounds like pretty good advice
Old Jun 30, 2003 | 02:44 PM
Didn't your gasket have those small plastic locator pins at the front and back??
Old Jun 30, 2003 | 03:11 PM
anaik's Avatar
It's been so long ago that I did it, I forgot all about those.
Old Jun 30, 2003 | 03:12 PM
InjectedSS's Avatar
get some of that copper gasket maker for the front and the back of the intake! then get some of the copper spray stuff that comes in a can and use that for the gaskets! guarantee that bish wont leak
Noenav
Mar 1, 2019 07:38 AM
HectorM52
Jul 30, 2017 11:46 AM
rcajun86
Jan 30, 2015 01:56 PM
cmdeshon
Dec 12, 2014 10:51 PM
