Re-install same (unused) head gaskets?
Old May 30, 2005 | 01:14 PM
96_pimped_out's Avatar
The head gaskets are not used. I bolted the heads on with new gaskets yesterday, but I might not have put the right side up and I meant to put my headers in place before the heads were on to save some time and forgot.
So, I'd like to pull the heads back off - but can I install those same head gaskets since I haven't used them? I'm assuming so, just wanted to make sure. I'm not tearing this thing down because of a blown gasket next week!
Old May 30, 2005 | 01:55 PM
BadBowS10's Avatar
Re: Re-install same (unused) head gaskets?
You should be fine. There shouldnt be a problem with doing that.
greg.
Old May 30, 2005 | 05:23 PM
NOMAD's Avatar
If you have already torqued the heads down, they have already deformed. You could use them, but I wouldn't suggest it.
-Shannon
Old May 30, 2005 | 05:28 PM
justnrt's Avatar
like nomad said, if they have been compressed, then you shouldnt reuse them. so much easier to replace now than when it fails.
Old May 30, 2005 | 07:42 PM
Unhappy Re: Re-install same (unused) head gaskets?
Well crap, I went to do the work after the first post before you two came along! I JUST finished reinstalling the heads for a second time with the same gaskets. Sigh...
The reason I'm taking so much care too is the fact that they're the Mr Gasket 5716 that are paper thin (.026 I think?). I guess I'll have to ponder of a few beers tonight whether I want to order a new set and do it a THIRD time.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
