Rattly Kinda Noise seems to be coming...
Old Apr 23, 2004 | 09:50 PM
wdz_lt1's Avatar
ok..when i drive down the street..i here this rattly kinda metal hitting metal sound..it is wierd and annoying fairly hi pitched sound..sounds like something is loose...but i checked under there and eveything is tight..its wierd it will do it sometimes while im braking
and sometimes when im just driving down the road..I can't really explain the noise although it is a really loud rattly noise...im pissed I want ti fixed but i can't explain it at all>>>really besides it seems like its coming out of behind me near the rear of my car..
ERRR IT IS SO ANNOYING AND EVERYONE CAN HERE IT WHEN I DRIVE BY....
if anyone know what im talking about...I will be so happy>>
i just want it fixed
Old Apr 23, 2004 | 10:49 PM
Cmr0z28's Avatar
Make sure the exhaust isn't hitting anything.
Old Apr 23, 2004 | 10:58 PM
camarokid24's Avatar
Man sounds like you have the same rattle noise I have! Mine started a year ago. It sounded like it was comming from around the tranny area. I took it to a mufler shop and they couldn't pin point it. I took it to a transmision shop and they couldn't tell me what it was either. It sounds kinda like metal chattering. Weather its in drive or in park. Does it get a little louder when you press on the gas and then disapear? Thats what Mine does. I initaly thought it was the heat sheild on the cat. Nope. I wish you luck finding the soarce. If you do find out what it is PLEASE let us know. Makes my car sound getto
Athony
Old Apr 23, 2004 | 11:03 PM
Tony Danza's Avatar
if its the random rattle from under your car is more than likely ruined cat, take it to the vet .
Same deal happend to me, the noise is the element in the cat houseing flippin out. I thought it was something rollin around loose in the transmission, thats exactly where the noise was comin from as far as i could tell. took i think a second for my mechanic to diagnose it as one of the cats
Old Apr 23, 2004 | 11:04 PM
Tony Danza's Avatar
Athony
same for you brotha, try to use this as an excuse to get a high flow cat for yourself!
Old Apr 23, 2004 | 11:45 PM
God I hope you are right man! I have been living with this dang chatter for over a year. Can I take off the cat or is it welded to the y pipe and if I do get it off can I tell anything by looking in it ? If this turns out to be my problem, I can now put an off road pipe on. I was going to get rid of my cat in a month for header install but tomarow is as good a day as any. Thank You Tony Danza
Old Apr 23, 2004 | 11:48 PM
Bersaglieri's Avatar
I had a rattle under the car, it turns out the I-pipe was hitting the g-load brace. Check that first, since its cheap to fix.
-Dustin-
Old Apr 24, 2004 | 02:07 AM
scoobysnax83's Avatar
-Dustin-
what is a g-load brace?
Old Apr 24, 2004 | 09:22 AM
Its like a stamped peice of sheet metal with 2 bolts on each side which attach the floor pans arcoss the drive shaft tunnel. Its found right after the I-pipe enters the driveshaft tunnel. Maybe some call it just a crossmember? My exhaust was boucing off of it when the engine torqued at certain RPM's.
-Dustin-
Old Apr 24, 2004 | 09:11 PM
Tony Danza's Avatar
haha well frist really make sure that nothin is smakin anything else or anything else obvious to make that noise, i think you would be let down to find that the rattle is still there after the cat is out.
PopoFormula
Oct 12, 2015 04:19 PM
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
colts0455
Jul 7, 2015 07:19 PM
