Can taylor 10.4MM wires go OVC?
Old Apr 24, 2004 | 06:09 PM
apached_driver's Avatar
Want to run Over the valve cover wires
But also want to run 10.4 mm wires
Do the taylor or any other allow for this since no one seems to have a 10.4 cut to fit solution
Anyone?
Old Apr 24, 2004 | 06:15 PM
RamAir95TA's Avatar
I think that 10.4mm wires are extremely overkill. You could probably get them to fit in drilled aftermarket looms, but I really don't see the point.
8mm or even 9mm wires are more than enough.
Old Apr 24, 2004 | 06:19 PM
CamaroSS30thAnn's Avatar
^^^ hes right 8mm or 9mm would be fine and taylor has a nice do it yourself OVC wire kit
Old Apr 24, 2004 | 06:20 PM
Clarification
I already have made for you looms to handle 10.4mm wires
Need to know if the normal 10.4mm are long enough to run that route over the the valve cover?
Old Apr 24, 2004 | 08:04 PM
Re: Clarification
if the 10.4 are for thr stock location the they will not be long enought to do OVC....correct me if im wrong
Old Apr 24, 2004 | 09:29 PM
Wondering
That's what I'm wondering,
Has anyone used a 10.4 mm wire set
in an OVC set up?
CobraEatr
Jul 24, 2004 11:37 AM
Burn_Out
Aug 18, 2002 08:49 AM
CobraEatr
Jul 29, 2002 11:46 AM
CobraEatr
Jul 23, 2002 06:32 PM
CobraEatr
Jul 22, 2002 09:49 AM
