Ratech solid pinion spacer and shim kit.
Old Feb 26, 2004 | 01:35 PM
CDN WS6's Avatar
I'm going to have motive 4.10's installed soon as well as a t/a cover and stud kit on my 6spd t/a. I'm wondering if it's a good idea to get the ratech solid pinion spacer and shim kit instead of going with a cush sleeve? Opinions please!
Old Feb 26, 2004 | 01:43 PM
Grease's Avatar
Most definately, the stock 10-bolt needs all the help it can get! I have that exact setup with Motive 4.10s which are actually 4.11s (a little stronger) and the gears have lasted a long time now. Before I was using a regular crush sleeve and always had problems with my pinion depth changing whenever I'd drag race with drag radials.
Old Feb 26, 2004 | 03:26 PM
BUBBA's Avatar
Just make sure your installer knows how to do it.
When I had my 4.10s installed, one outfit gave me the impression that they didn't know what I was talking about.
For that matter, an unscrupulous installer might tell you that they used the shims when in fact they didn't bother.JMHO
IndyZman
Oct 22, 2015 02:17 PM
95chwagon
Oct 16, 2015 12:24 PM
Daluchman1974
Sep 11, 2015 06:12 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
