Ran out of Gas
Old Nov 3, 2009 | 12:31 PM
ChiCrs's Avatar
Ran out of Gas
I ran out of gas today and I put some more in and I turned the key on and off 6 times and I hear the fuel pump come on but it wont start. What should I do next?
Old Nov 3, 2009 | 12:39 PM
meissen's Avatar
Replace your fuel pump Running out of gas is the most efficient way to burn your fuel pump.
To troubleshoot before replacing, check fuel pressure at the schraeder valve to make sure it's even building up enough pressure. You might be hearing the relay click and think you're hearing the pump. Seriously, the gas that's in the fuel tank is what keeps your fuel pump cool - running out of gas effectively burns the pump right up. You never want the gas tank to get below 1/4th tank or you'll risk allowing the fuel pump to overheat.
Old Nov 3, 2009 | 03:03 PM
bw_hunter's Avatar
The fuel pump relay is under a cover on the drivers floor. You don't hear the relay when listening at the tank...
The fuel cools the pump so it's important not to run the tank empty. However, there is no real need to keep a 1/4 tank of fuel in there...just don't run out.
Check the pressure after priming the pump by turning the key on and waiting without cranking the engine. The pumpwill run for a few seconds. If you don't get pressure then the pumpis likely shot....
Old Nov 3, 2009 | 03:08 PM
meissen's Avatar
If you're turning the key on and off, you'll hear the relay clicking (because you're inside the car, not at the tank).
Old Nov 3, 2009 | 03:10 PM
bw_hunter's Avatar
True, but the click will be under your foot and the pump is in the back. Even an old guy like me should be able to tell wher the noise is coming from....lol
Old Nov 3, 2009 | 04:37 PM
bubba4's Avatar
You said you put some gas in it and heard the pump come on. How much gas did you put in. I would put at least 5 gal. in it and if it dont crank then start the before mentioned pump checks. Good Luck! LF
pete53
Jun 27, 2015 09:08 AM
andrewcapps82
May 19, 2015 10:11 PM
zxtce
May 7, 2015 08:53 PM
simple
Aug 11, 2002 11:56 AM
jd13
Jul 30, 2002 10:35 AM
