Ran Datamaster NEED HELP!!!
Old Sep 7, 2004 | 10:16 PM
c0rey's Avatar
Unhappy Ran Datamaster NEED HELP!!!
Hey I really need some help here. My blower belt shredded and took out my fan wires, so I ran a datamaster log on the pig and here is what it came back with. Here are the codes I got from it. I also have a datamaster log if that will help the car just sputters and dies.
Codes:
MALF41: EST Open
MALF42: EST Grounded
MALF16: Lo-Res Fail
MALF37: Brake Switch Stuck On (maybe because I deleted abs?)
MALF46: Fuel Enable (VATS) Fail
Old Sep 8, 2004 | 01:31 PM
blkchevyz's Avatar
Re: Ran Datamaster NEED HELP!!!
http://wrenchman.freeservers.com/fordsux/gm.htm
not sure if that will help you or not
Old Sep 15, 2004 | 11:43 PM
c0rey's Avatar
Anyone else? I cant even get the car to start now :-(
Old Sep 16, 2004 | 08:32 AM
blkchevyz's Avatar
is it turning over?
does your security light stay on or blink.
Old Sep 16, 2004 | 04:40 PM
c0rey's Avatar
It turns over and starts but as soon as u hit the gas it dies. The Security light isnt on, Its just a code I pulled with datamaster.
Old Sep 16, 2004 | 04:43 PM
blkchevyz's Avatar
did you replace the fan wires? could one of them be shorting out?
Old Sep 16, 2004 | 04:45 PM
c0rey's Avatar
Fan wiring is fixxed.
Old Sep 16, 2004 | 04:55 PM
Sounds like you may have taken out the Opti wire as well. DTC sets when the PCM can't find the low resolution pulse signal from the Opti. It shuts down the fuel pump and injectors when that happens. Also check the wiring to the Ignition Control Module (ICM) and coil. That would cover DTC 41 and 42.
You will also get a start failure when the VATS (vehicle anti-theft system) doesn't get the right signal from the resistor in the key. Sounds like a possible problem with one of the engine grounds as well (there is one on the front of the engine near the ICM.)
Old Sep 16, 2004 | 04:56 PM
Kory 88 Iroc Lt-1's Avatar
You have a opti code and the vats is turning off your fuel.Turn off the vats in the computer, see if that helps. Did you shread your opti wire? that could account for the low res code.
Hope this helps,
Kory
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
95chwagon
Oct 16, 2015 12:24 PM
1bad427ls1
Sep 23, 2015 01:12 AM
