Ram Air Vs. Cai
Old Sep 16, 2003 | 04:56 PM
Formula03's Avatar
Ram Air Vs. Cai
I was wondering if any one has done a wind tunnel test to see if ram air outperformed cai or not. I have heard a lot of people's thoughts on this and i would like to hear more but what im really looking for is some actual proof which is better.
Old Sep 16, 2003 | 08:39 PM
Josh-'04 GTO's Avatar
Well, they didn't make "Ram Air Trans Ams" in '94 (just Firehawks), so I'm assuming you have an aftermarket hood. If it has a rain baffle like the OEM hoods, cut that out and install a Fernco connector in place of the necked down OEM MAF-to-TB connector. With those two mods, I'll take ram air over CAI anyday.
Old Sep 16, 2003 | 08:54 PM
Camaro_Maniac63's Avatar
On Firebirds, I can see the Ram-air setup having an advantage over the CAI. SS Camaros are a different story though...
Old Sep 16, 2003 | 08:56 PM
RamAir95TA's Avatar
Ram air is a myth because it does not exist, for the following reasons:
- Air is incompressible at any automobile speed., meaning that the kinetic energy of the air cannot be used to compress the air and raise the static pressure.
- The “ram air” nozzles commonly employed on automobiles tend to be the wrong shape. A divergent nozzle is required for ram air. Straight-profile scoops cannot provide a ram air effect.
Select one of the two types of intakes, warm air, or cold air. Beyond that its just about looks.
Old Sep 16, 2003 | 09:32 PM
ibanez6rg's Avatar
You'll see about the same gains from either or.
GeneCamaro's Avatar
When I switched from my ram air set up to FIPK I felt a difference. The ram-air didn't do anything.... Besides that, the Camaro set up has too many tight bends in it.
Old Sep 16, 2003 | 09:43 PM
383WS6's Avatar
HAHAHA.... First post... anyway, i went from a cut out WS6 hood that directly forced air (and water/bugs/small rocks) into the filter to a Vortech polished elbow w/ a SLP cai and lost an entire .1 at the track. probably my driving though.
Old Sep 16, 2003 | 09:58 PM
Formula03's Avatar
Yeah it doesnt have factory ram air but anyways what is the fernco connector.
Old Sep 16, 2003 | 10:10 PM
RamAir95TA's Avatar
A Fernco is a PVC pipe connector made of thick rubber, basically your new intake bellows. A 3" Fernco will fit with some motivation. You might need to boil it to make the rubber more pliable. They should run you around $5.00 or so.
Here's a picture of mine:
http://www.worldisround.com/articles/12201/photo13.html
Old Sep 16, 2003 | 10:12 PM
Cerwin Vega Fan's Avatar
Do a search, their is a lot more info on this subject in other threads.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
LT14LIFE
Feb 9, 2015 09:35 PM
rjc1629
Jan 27, 2015 10:46 AM
TitoPR221
Parts Wanted
Jan 10, 2015 09:21 AM
