Ram Air Intake Vs. Cold Air Intake
Old Jun 16, 2005 | 06:53 PM
Camarocracy's Avatar
Which intake system produces more horsepower on a 97 Firebird LT1?
A ramair hood with the ram air intake assembly and an air foil.
vs.
A cold air intake with a smooth intake elbow [Trickflow, Vortech] and an air foil?
I plan on buying a ramair hood later on, and I'm thinking on buying a coldair kit to hold me over until then. Probably won't buy the hood until fall/winter. I'm just wondering if the either intake systems produce more horsepower over the other?
Old Jun 16, 2005 | 07:00 PM
LtsRace's Avatar
Re: Ram Air Intake Vs. Cold Air Intake
I believe the hood with ram air produces a little more horsepower than a cold air intake. I think its somthing like 10 horsepower..at least thats what they claim. Ive got the suncoast creations hood and kit on my camaro. They say somthing in the neighborhood of 28 HP.
Old Jun 16, 2005 | 07:09 PM
Feenix's Avatar
Ram air does on average nothing more than a good CAI will do. I would just get a CAI now, and when you go to get the hood I would save the money on making it functional and just get the hood with maybe heat extractors instead. Unless you are doing it for performance and not for looks, in which case I wouldn't get the hood at all, just get a CAI and be done with it.
Old Jun 16, 2005 | 11:40 PM
trans9_5am's Avatar
In my learnings, ram air intakes help more at higher speeds than do non-ram air CAI's but the difference is minimal. I would go with a CAI for now unless you are getting the hood for looks and be prepared to dish out some money for a fully functional hood if so. JMHO
Brandon
Old Jun 17, 2005 | 02:36 AM
Dave '97 Z28 M6's Avatar
They're both effective, and I doubt that you'd ever notice any difference between the 2. As for the "ram effect", stock (or similar) ram air hoods simply don't have the scoop located in the right places to get significant pressure - the location, sitting right on the hood, is not in an appropriate spot. Just compare an SS or WS6 hood to a Pro Stocker's. And even with a scoop located high enough to be in the airstream, you'll rarely be traveling fast enough to get any benefit.
All that said, however, an f-body with a ram air hood certainly looks cool!
Old Jun 17, 2005 | 06:46 AM
97FormulaWS-6's Avatar
As for which makes more HP... to be honest it depends on if you make the necessary mods to the WS6 hood (Which makes driving in the rain a not so great idea).
If you de-baffle the hood, and use a smooth Fernco Coupler between the MAF & TB, you'll have the BEST CAI you can get.
If anyone wants to argue that point, I have to pose this information and question...
Mine is de-baffled and Fernco'd.... if I remove my airfilter and close the hood... I can SEE the TB blades through the hood... How does any aftermarket CAI with at least 2 bends and 2-3' of tubing flow better than that?????
As for if you'd notice the difference, I have no clue, I've never had a CAI on my car, just the WS6 setup, obviously.
Old Jun 17, 2005 | 04:32 PM
slomarao's Avatar
they will produce very similar numbers, if your good at working on cars then you could throw a ls1 lid on there. I have seen two guys on this board who have recently done it. I want to do it myself, that would make the most hp if that is what your after.
Old Jun 18, 2005 | 04:24 PM
bdc95ta's Avatar
Ram Air + lid should net you a noticable gain over a cai.
-b
Old Jun 20, 2005 | 12:35 AM
My Ram Air setup added 300HP..... or maybe that has something to do with the two braided hoses and the nitrous.
In any case, the Ram Air setup is about as straight and as simple as you can get, particularly when you open up the scoop, cut out the top of the airbox and use the Fernco coupling instead of the corrugated bellows. I see very little depression of MAP vs. barometric pressure, even over 7,000rpm.
http://cjcfo.fbody.com/members/injun...s/AirBox01.jpg
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
rcajun86
Jan 30, 2015 01:56 PM
thenewkid
Nov 27, 2014 09:41 AM
