ram air
Old Jan 28, 2007 | 06:32 AM
95 WHITE TRANS's Avatar
ram air
Hi i just got the oem slp ram air hood and air box (from slp) for my 95 ta.I see the majority of air box's for lt1's have four prongs to hold the air filter down mine just has two.Anybody know why.
THANKS
Old Jan 28, 2007 | 11:23 AM
2QUIK6's Avatar
I just bought the ram air box about a month ago and it has 4 screw down ***** across the back side that faces the motor. My friend has one thats not an SLP one, I think it was a Suncoast and it has 2 bolts, no ***** like the slp one.
Old Jan 28, 2007 | 11:42 AM
2000GTP's Avatar
Does the box appear to have two other provisions for fasteners? If not and if the two prongs do the trick keeping the air box secure and sealed, then I wouldn't worry about it.
Old Jan 28, 2007 | 11:49 AM
The OEM box, and the SLP Ram Air HO repro boxes all have 4 bolts/*****, at least everyone I have ever seen, including my own. If you bought it from SLP, they must have changed the design.
Old Jan 28, 2007 | 12:51 PM
I did a little search on other sites it seems to look like the one on 94 95 fire hawks.It's not like the one pictured on the slp web page, it dose not have those small cuts on the lid it looks a bit like the one injuneer has.Some firehawks have three prongs some five???? By the way mine is made in canada.
THANKS
PS I did a trial fit it seems to hook up ok now i'am having a hard time to put back the rubber elbow.
Old Jan 28, 2007 | 10:20 PM
Mine came from SLP with the full cover with the slots. I cut the top open.
I had both the SLP box and an OEM WS6 box at one time, and they were identical, except the SLP lid does not have the "Pontiac" and "Ram Air" logos cast into it, and does not have the molded rubber seal glued to it.
Old Jan 29, 2007 | 10:00 AM
2QUIK6's Avatar
Mine was exactly as pictured here..got it last month from SLP
http://www.slponline.com/view_produc...8&BIG=100008-1
Old Jan 29, 2007 | 09:07 PM
97formulakid's Avatar
I had a Suncoast and a factory Ram Air box. The Suncoast had two bolts holding it on while the factory had four ***** holding it on. Have any pics of what it looks like.
Old Jan 30, 2007 | 10:28 AM
I will try to get a picture on. I 'am almost certain that it's from a 94 95 hawk.I'am located in montreal and got the hood and box from the place (ZEKES)that originaly transformed the hawks ,ws6 and ss.The hood is old stock the true original gm one.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
LT14LIFE
Feb 9, 2015 09:35 PM
rjc1629
Jan 27, 2015 10:46 AM
TitoPR221
Parts Wanted
Jan 10, 2015 09:21 AM
