Radiator spraying antifreeze>>>
Old Jul 30, 2005 | 06:48 PM
mattbailey's Avatar
Well, I was trying to get the car ready for the track, and took it out on the street. The car was running pretty good, but I started smelling antifreeze. To me it looked like the lower radiator hose had antifreeze leaking out of it, so I fixed it, then I start the car up adding coolant, and the **** starts spraying out of the front of the radiator. I used to have my tranny cooler mounted there, don't know if it matters, but can I get this fixed or is it junk??? Also, can the radiator be made to cool better? I don't have the money right now for a Be Cool, but the car gets a little warm on the highway without OD. 3500 rpm at 75. Help me out fellas.
Old Jul 30, 2005 | 09:07 PM
Dave89IROC's Avatar
Re: Radiator spraying antifreeze>>>
you need a new rad, and as for temp on the freeway, don't go 75mph
Old Jul 30, 2005 | 10:10 PM
phinger23's Avatar
you car should not be getting too hot on the freeway...but as for the radiator...you have no choice to get a new one
Old Jul 31, 2005 | 07:41 AM
OBE1 95Z28's Avatar
I got a new radiator for $130 through a volume autoparts store. Looked identical to the stock one. I believe GM (discount sources like Dal) wants close to $200 for a new one.
Jeff1904
Jun 5, 2016 05:00 PM
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 01:46 PM
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
