Radiator hoses
Old Nov 28, 2003 | 11:38 PM
NewbieWar's Avatar
Radiator hoses
is there a kit i can get that has all the hoses?
ive got some that are leaking and some that look like they might start, so i could use a whole new hose set up
Old Nov 29, 2003 | 11:39 AM
$hawn's Avatar
Goodyear makes a kit, has all the hoses but one, from what I hear the hoses are blue colored, not the usuall black. Not sure who or where it is sold though.
Old Nov 29, 2003 | 02:05 PM
VegasZ's Avatar
www.summitracing.com sells the kit.
Old Nov 29, 2003 | 02:13 PM
Compstall's Avatar
I think Jeg's or Summit sells the kit you're talking about $hawn.
Old Nov 29, 2003 | 02:19 PM
jasons93z's Avatar
goodyears kit is expensive because its supposed to last a long time. If i were you, just replace the ones that need to be and save your money.
Old Nov 29, 2003 | 04:45 PM
Mtrhds94Z's Avatar
The Goodyear kit isn't really that pricey, since you get 10 of the 11 total hoses needed..[price each replacement hose, and add it up?]
The Goodyear engineers erred and the kit is one hose short...
A good kit tho..
Also note, that it is for 95-7 hose configuration, not 93-4[although you CAN update to late congifuration rather easily..]
Old Nov 29, 2003 | 06:34 PM
kevkop94TA's Avatar
If the Goodyear kit is a light blue color, that usually designates a higher temp hose than stock, so consider that as well, It's going to be a little heavier duty.
Old Nov 30, 2003 | 04:36 AM
NewbieWar's Avatar
what will i need to do to upgrade to allow for 95-97 radiator?
Old Nov 30, 2003 | 10:20 AM
95 Z/28 LT1's Avatar
Super Moderator
What hose is missing from the kit?
Old Nov 30, 2003 | 12:10 PM
$hawn's Avatar
NewbieWar, you dont have to change radiators, the one you have now will work, 95 Z/28 LT1 it's one of the heater hoses thats missing.
Old Nov 30, 2003 | 01:18 PM
NewbieWar's Avatar
well **** i dont have a heater core anyway
but i couldnt find the set for a f-body, only impalla lt1's
Old Nov 30, 2003 | 02:39 PM
Mtrhds94Z's Avatar
The kit # for 95-7 f body is #5006 Summit has them for about 100..
The missing hose is a heater hose, yes...
In this diagram[off shoebox' site] it's # 15:
http://shbox.com/1/heater_hoses.jpg
I just used a 14.5" piece of 3/4 heater hose for that.
To use 95-7 configuration on 93-4 you need a 'heater outlet hose connector' [bleeder pipe] without the 'tee' on it that the 93-4 has [The 95-7 one doesn't have a 'tee' in it] it is GM p/n 10262478
You do the 95-7 throttle body bypass, and route the TB hoses in 95-7 configuration...
This allows you to use the 95-7 radiator inlet hose, instead of the 93-4 inlet hose [that has that 'tee' in it, for the TB hose]... [see # 14 on both 95-7 and 93-4 on shoebox diagrams links below]
95-7:
http://shbox.com/1/95-97_hoses.jpg
93-4:
http://shbox.com/1/93-94_hoses.jpg
http://shbox.com/1/heater_hoses_93-94.jpg
I was going to do a write up,but never got to it...
Charlie
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
