Have some Problems-Please Help
Old Nov 29, 2003 | 10:27 PM
BLB 97 Formula's Avatar
Exclamation Have some Problems-Please Help
I just installed a new water pump on my 97 Formula and have some problems. Some coolant got onto the opti and it had to sit overnight and dry out before it would start up.
Now I am having a hard time starting the car, especially cold starts, but when it does start up it runs great, idles great, and doesn't miss at high rpm's.
Also, the cooling fans are now running ALL the time and are really loud. They're on from when the car starts till its off.
Any ideas on what is causing my hard starts and cooling fan issues and how to fix them??
Old Nov 29, 2003 | 10:31 PM
Compstall's Avatar
Temp switch in the water pump. Might want to check it out. Did you accidentally bust a wire or the connector, or even CONNECT the connector when you were finished? The hard start, fans on is DIRECTLY related to that temp switch.
Old Nov 29, 2003 | 11:04 PM
I will check the temp sensor. I am also getting a SES light if that helps out.
Anybody else have any advice? Thanks guys!
Old Nov 29, 2003 | 11:05 PM
Compstall's Avatar
Yeah, you can add the SES to those symptoms too.
"Been there, done that"
Old Nov 30, 2003 | 08:19 AM
Anybody else have an opinion on all of this?
Old Nov 30, 2003 | 09:24 AM
IT appears that all the sensors are connected properly, not sure what to check next. Could it be a blown fuse or relay that may be causing these problems?
Old Nov 30, 2003 | 10:39 AM
FastZinTennessee's Avatar
As long as the check engine light is on the fans will be on(I think). You need to get your car scanned if you can't visually see anything wrong with it, that will tell you why the light is on.
Old Nov 30, 2003 | 02:48 PM
LeeS's Avatar
I still think you need to check and make sure you didn't crack the Engine coolant temperature sensor or bend one of the prones on the sensor when you plug it back in.
Because if it is not plug up or is damaged the car will be hard to start and will flood for a few minutes then it will get slightly better. It gets better because it will go into open loop and just use store default values for the coolant sensor. It thinks you car is -60 degrees below zero.
Have a goodone! Lee!!
