Radiator HELP please!!
Old Oct 18, 2003 | 10:31 PM
pelebkf's Avatar
I have taken off the radiator on my 95 z because I have noticed a small leak creating a puddle on my driveway. I know it is coming from the radiator and I know it is coming from the fins on the radiator. I now have my radiator on the work bench an have tryed to find the hole all night with water and air. Unfortunatly I can't wait til monday to get to a shop to get it tested so I need some ideas on trying to find this leak. I thinks I know in about 3 inches where it is but I need a little more clarification before I try to fix it. Any one have any ideas????
Old Oct 18, 2003 | 10:37 PM
What they do at the shop is put low pressure air into the radiator and hold it under water to find where it bubbles.
Old Oct 18, 2003 | 11:09 PM
pelebkf's Avatar
I took your suggestion rob and got no air bubbles do you suppose it could be the ac condenser???
Old Oct 19, 2003 | 09:07 AM
Was the puddly definitely anti-freeze? Most anything that is going to leak from the a/c system will be in gas form. Perhaps you might want to rent a pressure tester for the cooling system, so you can track the leak down. Most often, a small puddle is caused by leakage from the water pump weep hole. It may intermittently leak a little right after the car is parked and then when pressure drops, it stops.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Pwilson59
Sep 3, 2015 08:47 PM
