Radiator flush?? And header bolts!!
Old Feb 23, 2010 | 09:16 PM
z28beast's Avatar
ok sorry bout the random title..i have 100k on my camaro.. my buddy has a machine in his auto shop at school that will suck out all the old antifreeze in my engine... i plan on replacing it with the prestone extended life coolent..but my ? is this..is it worth putting a bottle of prestone cooling system flush in and driving for a few days before changing my antifreeze or no? also i have bbk headers on my lt1 and the [EDIT] bolts keep coming loose and causing me to blow gaskets...whats the best locking bolt kit for my engine that wont break/bust when torqued to spec?? please leave brand/part number and or a link!! thanks for all the help guys! i love my new camaro and all the cool after market parts and the whole camaro community!
lol also my brake fluid is dark black.. if i do a brake system flush do you think it will stop my abs light from randomly poppin on? my breaks seem to work fine!! ( i plan on doing a flush anyways whats the best brake fluid to use?)
Last edited by Injuneer; Feb 23, 2010 at 11:38 PM. Reason: Do not override the language filter.
Old Feb 23, 2010 | 09:53 PM
dbrunner2's Avatar
Cooling system cleaner might not be a bad idea after 100k--you do want to flush it out well with water afterwards though, including through the heater core. As for the brakes, I don't know much about the functioning of the ABS on these cars (proud owner of a 1989 chassis) but black brake fluid CANNOT be good. Definitely at least flush it, and I'd consider a master cylinder rebuild while you're at it.
Old Feb 23, 2010 | 10:05 PM
z28beast's Avatar
a master cylinder rebuild?? is that something i could do?? or do i need a brake specialist?? and as far as the flush im going too add a bottle....and im going to empty out the system and refill with water a couple times..
Old Feb 24, 2010 | 11:34 AM
Z28SORR's Avatar
When you flush, drain and refill the radiator turn your heater on so that you get flow though the heater core. If your brakes are working fine? You don't NEED to rebuild anything! Just do the drain and refill first.
Old Feb 24, 2010 | 10:28 PM
z28beast's Avatar
ok thanks for all the help folks...any info on the header bolts??
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
kksi
Feb 17, 2015 10:41 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
