radiator fluid question
Old Nov 3, 2011 | 06:49 PM
94Z28LS1toLT1's Avatar
now when the radiator coolant is full i always heard to make sure its to the top of the radiator neck,now by that meaning does it mean to the top of the hole where the overflow hole is in the radiator? Today when i checked the fluid it was below the hole like i can see coolant but not all the way to the top.
I then ran the car when the temp got to the 1/4 mark i pulled the coolant dipstick to check the level and it was past the hot mark saying it was full,now is my radiator coolant level ok b/c it made me nervous not seeing the coolant level to the top of the radiator when i checked it.i just wanted to know if the coolant in the radiator is fine,thank u guys
Old Nov 3, 2011 | 06:57 PM
JGuy07's Avatar
Re: radiator fluid question
If its near the top, as if you can stick your finger down and into the coolant you're fine.
Old Nov 3, 2011 | 07:02 PM
Kevin Blown 95 TA's Avatar
It varies slightly with temperature because it expands and contracts. It usully stays full to the bottom or middle of the neck, but it can only suck in coolant from the resevoir when it is cooling down so it won't be higher than the hole to the resevior when it is cool. Yours sounds fine, Why you so concerned about it?
Old Nov 3, 2011 | 07:03 PM
Normally, it will be right up to the lip where the seal of the cap fits.
Old Nov 4, 2011 | 04:06 AM
lt1-xjs's Avatar
Coolant dipstick ?
Old Nov 4, 2011 | 06:31 AM
Originally Posted by lt1-xjs
Coolant dipstick ?
It's on the remote reservoir.
Old Nov 4, 2011 | 08:44 AM
lt1-xjs's Avatar
Lightbulb Re: radiator fluid question
Of course.
Old Nov 4, 2011 | 07:24 PM
yea my finger will able to touch the coolant
just making sure b/c a lot of problems in the past with coolant leaks,but this new radiator i put in in June a few months ago,everything does seem fine.thank u
yea the coolant is where the seal of the cap is thank u rob
PCLZ28
Dec 24, 2015 05:19 PM
grgguy
17
Feb 23, 2015 07:57 PM
alex5366
Feb 17, 2015 10:43 PM
ro2207
Dec 4, 2014 06:18 PM
