rad not full when cap is taken off
Old Jul 13, 2012 | 10:25 AM
javi805's Avatar
ive got a question but first ive have seen many post of problems with overheating on lt1, ok here we go, when the car is cooled down i take off the rad cap and the coolant isnt to the top.. i have checked for leaks, ripped hoses, & the metal tube that goes into the resivoir nothing. any ideas as to why?? by the way the car doesnt overheat at all the temp stays normal in the middle...any ideas would help thank you..
Old Jul 13, 2012 | 12:06 PM
Dave89IROC's Avatar
Rad cap ?
Old Jul 13, 2012 | 12:21 PM
My Red 93Z-28's Avatar
Is your oil light brown? Could have a head gasket leaking
Old Jul 13, 2012 | 12:35 PM
mrmint69's Avatar
Re: rad not full when cap is taken off
Radiator caps are real cheap and if it is old, I would replace and see how it responds. They do wear out over time.
Old Jul 13, 2012 | 12:39 PM
ACE1252's Avatar
Coolant system pressure tester......look up my other posts on it.
The coolant has to be going somewhere.....you need to find out where it's going. The above should help isolate it if the problem is in the engine. Is the overflow reservoir between the hot and cold marks? What is the level with the engine stone cold and the engine warmed up?
One simple possibility is that there could be a small hole in the hose that leads to that reservoir(from the radiator neck). That would cause the level in the reservoir to never move....due to it leaking on the ground. It would also prevent a vacuum from being generated to pull the coolant from the overflow back into the engine when it cools off(leaving a half empty radiator and overfilled reservoir).
Old Jul 13, 2012 | 12:58 PM
Also, check the coolant line that runs under the battery in a groove on the tray, I've had that leak before
Old Jul 13, 2012 | 01:03 PM
javi805's Avatar
i did check the oil and its normail.. the radiator cap is the orginal i will def take all think info and check the car again..its annoying!
Old Jul 13, 2012 | 01:05 PM
javi805's Avatar
i did test the hose and there was no hole on it.. it all seemed to be good
calaban
May 18, 2020 06:43 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Sandersen511
Jan 13, 2015 03:49 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
blac94Z
Nov 24, 2014 07:12 PM
