Rad fan switch options?
Ive got a 94 LT1 and Ive read they normally run @220 witch is to hot for my taste. On my 87 TA there a simple rad fan sensor on the pass head that I changed to a 180 temp for fan operation. Is this mod the same for the LT1 and will it have any negative affects on the way the fuel n air delivery system works? thanks
The fans are controlled by the PCM, and it takes the coolant temp from a sensor in the water pump. They are programmed to run so hot from the factory to lower emissions. You can switch to a 160 degree thermostat, run a manual fan switch (either buy one or wire it yourself), or have the PCM reprogrammed to turn on the fans sooner.
Shoebox has a write up on wiring your own fan switch:
http://shbox.com/1/fan_sw_diagram1.jpg
I just found this at summit, it seems like the same deal as what I did to my 87ta and it worked perfect. From what I understand the signal the pcm gets from the oe switch at @220 is changed to @195 with this. Basically plug n play. I maybe wrong but this is my understanding.
http://store.summitracing.com/partde...5&autoview=sku
The JET switch merely applies a ground to the fan relays at the temp stated to run the fans.
The JET switch is meant to work with the f-body LT1 electrical harness. It is inserted into the harness with the plug-in connectors. AFAIK, people have had no problems with it.
carguyshu
Jan 22, 2017 11:19 AM
