racetronix plug n play--walbro 255lph
...can u drop a 255 lph pump in the in tank tub or w/e like the racetronix kit, i think they use the walbro pump also (in tank tub being a small? fuel tub i guess inside the gas tank)
Re: racetronix plug n play--walbro 255lph
I did it on a 97. Used the plastic can with a walbro 255. Had to get a bit creative. Finding the glue for the plastic can is a trick. I tried seal all. Seams to work OK. Don't know what racetronix uses. I also used a KennyB BAP also. Still was'nt enough to feed 15psi of blower. Then went to 2 pumps. The plastic can went bye-bye, and replumbed all the fuel delivery. That worked. I cut a hole in the floor pan to get @ the fuel tank. Very convienient.
14
Aug 11, 2015 12:03 PM
