Racetronix Fuel pump Harness Question
Old Sep 27, 2004 | 10:00 PM
Serene's Avatar
I have my battery in the back, so it would be a waste for me to get the harness to run cable to the back of the alternator when I already have a 4 ga wire coming from the alternator to the back for the cutoff switch. Can I just take a 10 ga wire to the existing relay? What relay would I need to do this too?
Old Sep 27, 2004 | 10:49 PM
ltlhomer's Avatar
Re: Racetronix Fuel pump Harness Question
TTT for ya buddy.
Old Sep 28, 2004 | 12:05 AM
Not familiar with the Racetronix harness, but there would be no reason to run a power lead to the alt when the battery is in the back. Just run it to the battery instead. This would be only if you get good voltage at your rear mounted battery from the alt. If you don't, then you might want to run the lead to the alt.
Old Sep 28, 2004 | 12:27 AM
Serene's Avatar
I know, but the alternator wire comes all the way to the back
Old Sep 28, 2004 | 04:26 AM
Racetronix's Avatar
You will still have voltage drop. The voltage is ALWAYS highest at the output of the alternator. This is the best location to get power for your pump. Same goes for your injectors and ignition coil.
The other option is to order a custom length short harness.
What type of pump are you running?
Old Sep 28, 2004 | 04:51 AM
Spinner's Avatar
I think what he's saying is he'd have less of a voltage drop with his 4ga wire then the wire in the racetronix kit?
Old Sep 28, 2004 | 09:47 AM
Serene's Avatar
why would I want to run another 10ga wire to the alternator when i already have a 4 ga wire back near the fuel pump?
Im going to be running your lt1 pump kit.
Old Sep 28, 2004 | 12:50 PM
Serene's Avatar
anyone?
Old Sep 28, 2004 | 12:55 PM
Racetronix's Avatar
anyone?
You are running a cutoff switch?
The pump must be wired so power is disrupted when the cutoff switch is off in order to pass track tech-in.
You will require a custom length harness.
E-Mail sales@racetronix.com to order one.
Old Sep 28, 2004 | 02:08 PM
Serene's Avatar
i dont have enough cash to buy the pump and harness, so I figured I could make the feed wire bigger to the relay, thats why Im asking this. I have all sorts of wire laying around here though. If I did have enough money id buy both. Is the custom harness more expensive?
Hooking it up to pass tech is no problem, just hooked on the cutoff switch opposite the alternator feed.
Old Sep 28, 2004 | 02:34 PM
Racetronix's Avatar
A custom length harness would be the same price.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
RiverMutant96
Jan 30, 2015 09:21 AM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
