racetonix fp harness?
Old Sep 14, 2005 | 01:14 PM
  #16
Black_95Formula's Avatar
Re: racetonix fp harness?
Originally Posted by 1racerdude
You my friend didn't read all the posts.
This guy cut the fill neck of the tank under the car and was telling people that's how it should be done. Yea if ya want to chance blowing your *** up.
Now that's dumb. I was just talking about using air shears -- which don't allow you to cut more then thin sheet metal unlike an electric hacksaw or something similar. Plus these shears use an air compressor so no electricity, and are relatively cheap on eBay ~ $20.
If done right, the trap door method is very good. The only problem I can think of doing it this way (other then the risk of sparks) is that you don't clean the tank out but just throw a new pump in, so if your old pump went because of clogs this won't fix it but probaly make it worse.
Old Sep 14, 2005 | 01:23 PM
  #17
simple's Avatar
call it dumb/stupid or whatever you want, again i have never seen a hacksaw cause a spark EVER!!
it worked for me...i'm still here
but i'll put a disclaimer just for LR. dont try this because there is a remote possibility of blowing yourself and many things around you up
but theres also a remote possibility of a hot smoltering nugget of metal melting a gas line while someone welding your exhaust under the car
theres also a remote possibility of cutting gas lines while doing the trap door method
and too be honest...i didnt tell anyone too do it my way now did I?
have a nice day fellas
Old Sep 14, 2005 | 01:33 PM
  #18
Dumb as in I would not do it, but if I was on a deadline who knows I sure have done a lot of "dumb" things in the past, and to each his own. Glad it worked out for ya.
Old Sep 14, 2005 | 02:17 PM
  #19
1racerdude's Avatar
Ya damn sure posted it up there for some body to try and it's STUPID.
Cut my door with a nibbler because I have seen the results of a tank explosion.
G-BODYT56
Jan 14, 2022 11:14 PM
whitehooptie
Aug 10, 2015 07:02 AM
Henson071
Aug 4, 2015 09:32 AM
Thirim
Jul 30, 2015 01:29 PM
RUNMYTA
Jul 15, 2015 07:50 PM
