race tomorrow
Old Apr 6, 2007 | 12:43 AM
wheelliftnpony's Avatar
race tomorrow
goin to the strip tomorrow, any tips for a stock lt1 with catback, cai, msd ignition, street tires? i have a miss could this be the cat? would a cat delete help this? thanks
also, how would removing the front sway bar help, if at all?
Old Apr 6, 2007 | 06:51 AM
squints88's Avatar
pop off the sway bar, spare tire/jack, and any other junk you may have in there. Drop the pressure in your tires, 25 or so if they are normal street radials, and if you think its the cat lose that too for a day!
I ran this week with the mods below on 2.73's and she put down a 13.7
Old Apr 6, 2007 | 06:55 AM
joeSS97's Avatar
Fix your miss,then go to the track.Pretty simple.How can you expect to get any kind of decent base times?
Old Apr 6, 2007 | 07:22 AM
Javier97Z28's Avatar
Moderator
Don't go to the track with a miss, not a smart idea at all.
As joe above mentioned, fix your problem, then go to the track.
As far as what's causing it, a miss can be caused by just about anything.
Old Apr 6, 2007 | 10:41 AM
2000GTP's Avatar
There are several culprits for a miss: plug wire, actual plug, fuel injector, a vacuum leak to name a few...I would fix that before even attempting to race.
Old Apr 7, 2007 | 11:07 AM
canuck94z28's Avatar
Check to see if your plug wires are secured or not broken etc as this will cause off idle miss and once you get it fixed then go to track,otherwise your just wasting money.
Old Apr 11, 2007 | 04:22 PM
well, we found the problem with a miss he was havin. after he ran. since we didnt drop anything when we re-did the plug wires, and plugged the boots onto the plugs from the top, he had the boot for the #6 plug on a manifold bolt..causing a miss and obvious arching.. so he ran a 14.8 on 7 cylinders.. what should we expect on all 8? could we be lookin 13s with full MSD, exhaust, intake, shift kit, take the sway bar off, and run slicks?
Old Apr 11, 2007 | 04:34 PM
2000GTP's Avatar
A plug on the manifold bolt.. that'll definitely do it. At least it was a simple fix.
Old Apr 11, 2007 | 07:44 PM
ChevyTuffD.A.'s Avatar
13's would be VERY possible as long as the car is running good.
Old Apr 11, 2007 | 07:49 PM
squints88's Avatar
yea like I said, I ran a 13.7 with everything in my sig, if his car runs like mine does and you throw on some decent tires it will turn in some good times!
Old Apr 11, 2007 | 09:32 PM
1badasZ's Avatar
i know every car is different but my car ran faster for some reason when i took the hypertech off. the engine tuning anyway
Old Apr 11, 2007 | 10:39 PM
k thanks guys we're goin to mason-dixon (hagerstown, md) on the 22nd this month.. ill get back on here and update those times hopefully
Boss002
Jan 20, 2016 12:17 PM
NewsBot
Jul 29, 2015 08:10 PM
Boss002
Jul 24, 2015 10:47 AM
Z28amustangklr
Jul 18, 2015 11:05 AM
