Race Only Heater Delete
OK , I know this has been beaten to death but I just want to be sure. I am converting my 1995 Formula to drag race only. I can loop or plug the two heater line elbows on the passenger side of the water pump. Then do the TB bypass and run the line from the back of the heads directly to the radiator connection below the filler cap. I need to leave the small radiator hose from the elbow on the driver's side of the water pump to the smaller connection on the lower driver's side of the radiator. Is this correct?
THANKS
Jim
THANKS
Jim
FMFRacing88
May 25, 2015 08:08 PM
alex5366
Mar 8, 2015 11:32 AM
Jan 23, 2015 01:13 PM
