Quick ? on stock coil
Old Jan 2, 2004 | 04:18 PM
Showme's Avatar
Hey,
I'm in the middle of changing the coil on my car.
I have it off...but how in the world do I disconnect the coil itself from the housing.
Its being held in place by two rivits it think.
Once those rivits are out...what do I replace them with.
Tim
Old Jan 2, 2004 | 04:21 PM
BC56F100's Avatar
If I remember correctly you should use two long small bolts with nuts. What kind of coil is it?
Old Jan 2, 2004 | 04:43 PM
Stock coils are riveted to the bracket. Something along these lines should help.
Old Jan 2, 2004 | 04:47 PM
AsianSensation's Avatar
I used a dremel.
http://www.97ta.com/msd_ignition_coil.shtml
Old Jan 5, 2004 | 09:51 AM
Showme's Avatar
I know its been a few days.
I had to take care of a sudden family medical emergency.
I just left the car up on stands and took off.
But anyway...I took off the coil and put it the brackets back together wrong.
Once I put the brackets behind each other with the holes lining up...it slip right back into place.
From there it only took 10 min to button everything back up.
Thanks for the help everyone
Tim
Showme's Avatar
Tim
RUENUF
May 25, 2016 08:10 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Catmaigne
Dec 25, 2014 12:16 PM
