Quick review
Quick review
Hey guys I made a list of everything I think I need, Im planning on doing a cam swap next month and wanted to be sure I have everything I need to buy, Still not sure on what cam to get but im leaning towards the 230/236, Any helpful comment are appreciated
LT1/LT4 Camshaft Swap Gasket Package
Comp Cams Hi-Tech One-Piece Chromemoly pushrods, 7.200" (OEM Roller - Factory Length)
Crane Gold Self-Aligning, Narrow Body Rocker Arm for Center Bolt Valve Cover, 3/8" stud, 1.6
Comp Cams 26918 Beehive Ovate Spring
Comp Cams 10 degree Steel Retainer for Comp 26918 valvespring.
Comp Cams 11/32 10 Degree Machine Steel Locks, set of 16
Comp Cams "Extreme" LT1 Camshaft, 224 / 230, .502 / .510 112 LSA
Comp Cams "Extreme" LT1 Camshaft, 230 / 236, .510 / .520, 112LSA
also a electric W/P and clodes chain
I have seen an install on the web - I'll try to post the link - where the beehive retainers were not compatible with the Crane SA rockers.
Is this indeed the case?
http://www.97transam.com/97ta-cam.php
I am very interested in this as I am thinking of a similiar install and I have a set of GMPP SA rockers- same as yours
To get installed height with beehives you pretty much need longer valves or retainers/locks to raise the installed height. The later will cause SA rocker issues because it raises the retainer higher on the valve leaving less tip sticking out for the SA portion of the rocker to guide against.
I took it as a question about retainer to seal clearance, I don't know the answer though.
Can anyone else step in who has experience with the beehive type spring and SA rockers.......
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
tommalcolm
Sep 11, 2015 03:39 PM
