Quick Rear O2 Sensor Question...
Old Mar 29, 2004 | 06:41 PM
1996 | Z28 SS's Avatar
After I install my Jet-Hot LT headers.. I need to drive over to an exhaust shop and have them custom fab a y-pipe for me. So that means I'll have to drive there open headers. My two front O2 sensors will be in.. but what about my rear one? What do I do with it? Will it be fine not hooked up and reading anything for the 30min drive? I'm just a little confused... Thanks!
Old Mar 29, 2004 | 07:53 PM
Dave89IROC's Avatar
you'll be fine, it is just to monitor the functionallity of the cat., you might set a code, that's it
Old Mar 29, 2004 | 08:39 PM
GreenDemon's Avatar
Front o2s measure emissions from engine and adjust fuel as neccessary.
Rear o2s measure performance of the cat and tell you if there's something wrong with it.
You could drive around all day with the rear o2s unplugged if you like seeing the ses light.
Old Mar 29, 2004 | 08:40 PM
Oh ok, thanks.. I wasn't sure.. thought maybe it would do something with the A/F ratio and my car wouldn't run well enough to get to the shop..
Thanks!
Old Mar 29, 2004 | 09:02 PM
stereomandan's Avatar
I'm drove around last week with the rear O2's removed after my header install. All I got was the SES light.
Now my PCM is on it's way to MADWOLF, i.e. Ion at www.madz28.com to get a tune and delete the O2's from the PCM
Dan
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
