Quick Question Regarding Valve Adjustment
Old Feb 15, 2006 | 11:31 AM
Deenasty's Avatar
Im going to be adjusting my valves tonight, with the car running. Im going to put a 1/4 turn past zero lash (Trust me I know how to find zero lash). Im running stock comp replacement lifters. After I find zero lash, And I shut the car off to put the preload on, does it matter if the valve is closed or open?
Old Feb 15, 2006 | 11:36 AM
blkchevyz's Avatar
Re: Quick Question Regarding Valve Adjustment
last time i did it running i just went till it stoped clicking, then went 1/2 a turn more. so i did the pre load while it was going... i just didnt do the polly lock till it was off.
boy was that messy
Old Feb 15, 2006 | 11:55 PM
If you are using the "engine running method", you don't shut it off to do the preload, you do it while the engine is running. That's why the method has that name.
Old Feb 16, 2006 | 11:22 AM
Deenasty's Avatar
I see.... thanks rob, I was doing it wrong! What a moron I am..
oldschool
Feb 9, 2016 09:21 PM
Jazsun
Dec 29, 2014 12:14 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
