Quick question. Please look...
Old Mar 28, 2008 | 02:16 PM
EsCrasston's Avatar
Ok... So I had the infamous intake manifold leak so i pulled the intake and replaced the gasket and did the egr blockoff and so on.. put everything all back together, connected everything and waited a few days for the permatex to set.. i started it up a little bit ago and the fans came on right away. any reason this should be happening? i thought it might have been my manual fan switch, but i turned the car off and tested the switch and it was working fine. any idea why my fans would do this? is it just because it's been parked for 5 months? i appreciate your input.
Old Mar 28, 2008 | 02:45 PM
Is your SES on? If so, the fans will be, too.
Old Mar 28, 2008 | 02:49 PM
EsCrasston's Avatar
The fans come on with the service engine light???
Old Mar 28, 2008 | 02:59 PM
2000GTP's Avatar
For certain DTCs the fans will kick on automatically.
Old Mar 28, 2008 | 03:04 PM
EsCrasston's Avatar
hmm... i did not know that... i guess its true that you learn something new every day.. thanks alot for the help!
Old Mar 28, 2008 | 07:08 PM
The_Bishop's Avatar
What year car? If you deleted the EGR solenoid, it'll set a code, which will trigger the light and fans. You need to pop a resistor in place of the solenoid. That is, if you have a 94-95. OBDII cars are different.
Old Mar 28, 2008 | 08:53 PM
EsCrasston's Avatar
My car is a 94.
Old Mar 28, 2008 | 08:59 PM
EsCrasston's Avatar
and what type of resistor do i need? one that just plugs into the wire?
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
