Quick question...how to use the belt tensioner
Old 05-06-2007, 03:15 PM
micfly83's Avatar
So I'm trying to take my alternator off
and I read you obviously have to loosen the belt with the belt tensioner
How do you do it?
I took a 13mm socket and turned it counter clockwise and the bolt just came out.
Then I put it back in and tried tightening it and it just kinda spins...
I guess I dont understand the system.
micfly83 is offline
Old 05-06-2007, 03:23 PM
bingo's Avatar
You turn the bolt clockwise to relieve tension on the belt.If it is spinning you either don't have the bolt in properly or you nessed up the tensioner. http://shbox.com/1/accy_brkt.jpg
bingo is offline
Old 05-06-2007, 03:29 PM
micfly83's Avatar
I still dont understand
I turn it clockwise and then what?
micfly83 is offline
Old 05-06-2007, 03:47 PM
always faster's Avatar
Well lets make it simple:
-13mm sokets with a ratchet on the tensionner bolt.
-Turn clockwise and the tensionner should should come down.
-With the tensionner down you should have more than enough slack in the belt to take it off.
There i nothing more to say
always faster is offline
Old 05-06-2007, 03:49 PM
micfly83's Avatar
Then I guess the bolt is stripped?
It just spins and spins and spins...itll sort of gettin tight for like a 3 year old girl, then it spins again.
micfly83 is offline
Old 05-06-2007, 03:56 PM
Yup you need a new tensionner.
Old 05-06-2007, 03:58 PM
micfly83's Avatar
Can you explain why?
All I did was take the bolt out and put it back in and it spins...I dont see how i stripped anything
micfly83 is offline
Old 05-06-2007, 04:00 PM
Take the bolt off and the pulley.Could you see the thread inside the tensionner to see if those are damaged?
This would give you a good idea.
Old 05-06-2007, 04:01 PM
micfly83's Avatar
If I do this...will I be able to get the pulley back on?
micfly83 is offline
Old 05-06-2007, 04:04 PM
Dave89IROC's Avatar
well, the belt will come off, so yes
Dave89IROC is offline
Old 05-06-2007, 04:06 PM
micfly83's Avatar
ok i'll go out and do that
micfly83 is offline
Old 05-06-2007, 04:07 PM
FlamingChicken's Avatar
if not they are pretty cheap. i had one fly off one night at WOT and replaced it in the parking lot with a autozone special. if the bolt isnt tightening what else could be the problem other than it stripped?
FlamingChicken is offline
Old 05-06-2007, 04:26 PM
micfly83's Avatar
yea its stripped.
i banged on it and metal shavings came out
Can I get them somewhere locally?
(I dont know what an autozone special is)
micfly83 is offline
Old 05-06-2007, 04:38 PM
Dave89IROC's Avatar
yea its stripped.
try all your local auto parts stores, one should have one in stock
Old 05-06-2007, 05:20 PM
micfly83's Avatar
Ok i got it
$26, not bad
So
Now what do I do to ensure that I dont screw this one up.
Right now the old tensioner is on there...tensioning...
Its stripped
Whats the best method of putting this one on.
I still need the belt untenioned for the alternator too
micfly83 is offline
Quick Reply: Quick question...how to use the belt tensioner
