Quick question...how to use the belt tensioner
So I'm trying to take my alternator off
and I read you obviously have to loosen the belt with the belt tensioner How do you do it? I took a 13mm socket and turned it counter clockwise and the bolt just came out. Then I put it back in and tried tightening it and it just kinda spins... I guess I dont understand the system. |
You turn the bolt clockwise to relieve tension on the belt.If it is spinning you either don't have the bolt in properly or you nessed up the tensioner. http://shbox.com/1/accy_brkt.jpg
I still dont understand
I turn it clockwise and then what? |
Originally Posted by micfly83
(Post 4585882)
I turn it clockwise and then what? -13mm sokets with a ratchet on the tensionner bolt. -Turn clockwise and the tensionner should should come down. -With the tensionner down you should have more than enough slack in the belt to take it off. There i nothing more to say ;) |
Then I guess the bolt is stripped?
It just spins and spins and spins...itll sort of gettin tight for like a 3 year old girl, then it spins again. |
(Post 4585905)
Can you explain why?
All I did was take the bolt out and put it back in and it spins...I dont see how i stripped anything |
(Post 4585922)
All I did was take the bolt out and put it back in and it spins...I dont see how i stripped anything Take the bolt off and the pulley.Could you see the thread inside the tensionner to see if those are damaged? This would give you a good idea. |
If I do this...will I be able to get the pulley back on?
(Post 4585925)
ok i'll go out and do that
if not they are pretty cheap. i had one fly off one night at WOT and replaced it in the parking lot with a autozone special. if the bolt isnt tightening what else could be the problem other than it stripped?
yea its stripped.
i banged on it and metal shavings came out Can I get them somewhere locally? (I dont know what an autozone special is) |
(Post 4585957)
yea its stripped.
Ok i got it
$26, not bad So Now what do I do to ensure that I dont screw this one up. Right now the old tensioner is on there...tensioning... Its stripped Whats the best method of putting this one on. I still need the belt untenioned for the alternator too |
