Quick question on head bolt torque!!!!!!!
Old Sep 27, 2004 | 07:18 PM
RealQuick's Avatar
My chiltons says 22in-lb which has to be wrong for 96-97 LT1's. Its says 65lb-ft for 93-95 LT1's. I am currently putting a head back on a 96 z28 and want to know what I should torque to. Should I do 65lb-ft like the 93-95's? need help quick. Thanks.
Old Sep 27, 2004 | 07:24 PM
95 Z/28 LT1's Avatar
Super Moderator
Re: Quick question on head bolt torque!!!!!!!
Did you try doing a search here in this forum?
Old Sep 27, 2004 | 07:34 PM
That would be 22 lb. ft. before adding the required angle torquing. (additional 67º for the short bolts and 80º for long and intermediate bolts)
Old Sep 27, 2004 | 08:16 PM
RealQuick's Avatar
Angle toprque? So torque them all 22 lb-ft and then the short ones should be torqued 67 additional degrees and the long ones will go around an additional 80 degrees? I am having a hard time understanding it then...please specify. Thanks.
Old Sep 27, 2004 | 08:38 PM
KenP's Avatar
You would need a torque angle meter similiar to this http://www.thetoolwarehouse.net/shop/LIS-28100.html to do that. I just torqued my heads to 65 lbs. in 3 increments 20,40,65 lbs. using a standard torque wrench.
Kenny
Old Sep 27, 2004 | 08:40 PM
RealQuick's Avatar
Originally Posted by KenP
You would need a torque angle meter similiar to this http://www.thetoolwarehouse.net/shop/LIS-28100.html to TTY. I just torqued my heads to 65 lbs. in 3 increments 20,40,65 lbs. using a standard torque wrench.
Kenny
Cool. As long as you didnt have any problems. Thanks for the link.
Old Sep 27, 2004 | 09:14 PM
Kenny
Yeah, I have that very meter. Torque-angle is more efficient in providing uniform clamping forces as it is less affected by friction. I assume that is why GM changed the specs in 1996 from the previous straight torquing method. Probably a little better with aluminum heads on cast iron block, like the LT1.
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
