Quick Question Bout Balancer Pulley
Old Mar 28, 2003 | 09:03 PM
lrm95transam's Avatar
what is a good way to stop the crank from moving when removing the harmonic balancer? so that when u try to losen the bolts the crank dont spin
Old Mar 28, 2003 | 10:33 PM
If you use a breaker bar or something long for leverage and a 6 point socket, you can usually give it a "pop" quickly and they will break loose. If not, slip something through the spokes of the pulley and let it spin until it safely wedges against something.
You could also try a "strap wrench".
Old Mar 29, 2003 | 06:12 PM
leadfoot94's Avatar
I just used an impact with the correct socket, so it would only turn the bolts, came off really easy.
HectorM52
Jul 30, 2017 11:46 AM
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
