Quick Question Bout Balancer Pulley
what is a good way to stop the crank from moving when removing the harmonic balancer? so that when u try to losen the bolts the crank dont spin
If you use a breaker bar or something long for leverage and a 6 point socket, you can usually give it a "pop" quickly and they will break loose. If not, slip something through the spokes of the pulley and let it spin until it safely wedges against something.
You could also try a "strap wrench".
stockssn2o
May 25, 2015 08:54 AM
