quick question
Old Apr 23, 2009 | 03:12 PM
cory123456's Avatar
quick question
would i have to port my heads/intake and get a bigger throttle bodie for this cam Xtreme Fuel Injection, 292XFI HR13? thanks.
Old Apr 24, 2009 | 05:14 AM
Guest47904's Avatar
Guest
If you notice in the information sheet at comp cams regarding that cam. It would appear it's a top end cam not a low rpm torque type cam. So unless you are interested in circle track racing, it's probably not for you. Most of us stop light racers want low rpm torque.
Don't just jump to the bottom of the page when it comes to cams.
Old Apr 24, 2009 | 06:31 AM
96capricemgr's Avatar
That cam tested on a stock shortblock with Lingenfelter heads had not yet peaked when the pcm ran out of rpm at 7000rpms.
Comp's rpm ranges are WAY lower than reality, making some of their spring recommendations incorrect too.
On a stock shortblock you need to keep duration under 230. If you want a Comp look at the comp 503.
The XFI stuff is hard on valvetrain and doesn't really make great power either.
Old Apr 24, 2009 | 02:33 PM
cory123456's Avatar
ok thanks
Old Apr 24, 2009 | 04:00 PM
Look for posts by "fergymoto" on LS1tech, he was the one who tried it on a stock shortblock.
Currently he is running the AI 226/234, he will freely admit that XFI grind was WAY too big.
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
