Quick question!
Old Mar 2, 2007 | 10:28 AM
94_camm's Avatar
Quick question!
I had my motor built a motor shop local.after it was done i put it in my garage to put some other stuff on to it.i then ordered heads 2 weeks after that.i since then torqued the heads down to the block.i went to the motor shop before and the guy said that i should check to see if the valve hits the piston.do i really have to take the heads off and do that or am i fine?
heads-trickflows
Old Mar 2, 2007 | 11:05 AM
rskrause's Avatar
Moderator
If there is anything non-standard about it, piston to valve clearance should be checked.
Rich
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
