Quick Optispark question
Old Jan 26, 2004 | 12:04 PM
95BlackTA's Avatar
Im not sure what the previous owner did, but he gave me an extra opti when I bought the car. It was the original one that came on the car, and he replaced it trying to find a stumble...turned out it was plugs wires. Well now this opti is going bad, so im putting back in the old one. It looks like he unscrewed these two LITTLE weird screws..they are both sticking out. But when I spin them they dont do back in. Are these supposed to be like this? Or should all bolts and screws on the opti be tighened down. Its a 95 vented.
Thanks guys. If you need a pic let me know, I can snap one with my phone.
Old Jan 26, 2004 | 12:18 PM
ASTROJOE LT1's Avatar
There are four Torx #4 size screws holding the cap on. Yes they need to be tightened down to hold the unit together and prevent moisture from getting inside.
Old Jan 26, 2004 | 12:22 PM
95BlackTA's Avatar
ok thank you
Old Jan 26, 2004 | 12:40 PM
twdz28's Avatar
If the unit still works which we hope it does for you... You need to use some silicone before you tighten everything down because of moisture getting into the unit...
Old Jan 26, 2004 | 01:24 PM
95BlackTA's Avatar
Quick question about that. Im doing the opti change tomorrow, and ill be putting that silicone sealant on the gaskets..and I guess the opti too since you said to. It says takes 24 hours to fully cure. Well Ill be doing it tomorrow at prolly like 2Pm, and I gotta go to school the next day at 930AM. Thats only like 19 hours. Will that be enough time to cure?
Also, right after I install it, should I wait to even turn it on before it cures? Or just start the car to make sure I installed the opti right, then turn it off before it heats up.
Old Jan 26, 2004 | 09:45 PM
95BlackTA's Avatar
anyone ??
Old Jan 26, 2004 | 10:14 PM
I really wouldn't worry about it. There won't be any pressure or anything in the opti to "blow" the seal. I would defintely crank the car up right away to see if it works.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
94Form
Feb 10, 2015 11:23 PM
Injuneer
Dec 15, 2014 09:36 AM
