Quick oil pan ?
Old Aug 21, 2003 | 07:19 PM
RiceETR96's Avatar
Quick oil pan ? Motor finished just need a bigger pan.
Just wondering if there is another pan that fits the LT1's with no modifications? Canton is back ordered for 3 weeks, I leave on deployment in 1 week, and My motor is only lacking this dang oil pan. I have the HV pump and won't settle for the stock pan. I have found one but I wonder if anyone is using it???
Milodon
Old Aug 21, 2003 | 08:27 PM
Dave Feerst's Avatar
I wish i could help you but i heard soo many horror stories about the aftermarket pans that I went a different route... see my oil accumulator post from yesterday.
Old Aug 21, 2003 | 11:31 PM
CBalke's Avatar
Stroker Pan
I bought the miloden stroker pan and it fits just fine. However I am using an aftermarket K-member. I am unsure as to which pick-up to run right now but otherwise I test fit the pan and if clears the crank and the rods. I am not sure if this helps out at all.
Later Colin
Old Aug 22, 2003 | 04:19 AM
RiceETR96's Avatar
TTT, anyone else?
Thanks for the replies guys. I'd like to find someone with a stock K-member running that pan with no problem.
Old Aug 22, 2003 | 08:33 AM
Xscream's Avatar
It will not fit a factory Kmember in a 4th gen, unless they have changed the pan design from two years ago. Best of luck, you can try and get a pan from TPIS, etc... these places commonly stock the pans.
HectorM52
Jul 30, 2017 11:46 AM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
