Quick Intake Manifold Question
Old Jan 31, 2006 | 02:57 PM
My Iroc Z28's Avatar
I purchased a new painted and ported Intake manifold on the bottom theres hex head plugs that need to be installed, does anyone know what they should be torqued to? I want to make sure there nice and tight so they don't leak or fall out after installed. Thanks
Old Jan 31, 2006 | 03:22 PM
RamAir95TA's Avatar
Re: Quick Intake Manifold Question
I'd say 20 ft. lbs. would be plenty. There should be a heat shield over those hex plugs, so even if they DID fall out, they would be contained. The plugs block off internal EGR passages.
Old Jan 31, 2006 | 03:25 PM
I got the heat shield also but i need to reuse my old bolts for that. i just want to make sure i don't over tighten them.
Old Jan 31, 2006 | 04:07 PM
SStrokerAce's Avatar
Takes more than 20ft lbs to get them out..... they are a tappered thread I think so just tighten them down hard.
Bret
Old Jan 31, 2006 | 04:16 PM
Bret
What are you thinking.... Hand tight with a 3/8 rachet or should i use a impact? Also should it go down flush or should i still be able to see threads on the plugs? Im also worried about potentialy cracking the intake.
Old Jan 31, 2006 | 05:47 PM
LameRandomName's Avatar
Just crank them down good with a ratched. I don't mean to twist them to within an inch of their lives, I mean just crank them down to where it feels "right".
And if it were me, I'd use anti-seize. Lightly.
Old Jan 31, 2006 | 05:51 PM
Kevin Blown 95 TA's Avatar
Just screw them down tight by hand with the allen wrench. If you're worried about them rattling loose, use some non-hardening sealer on the threads. They're not that of a big deal.
Old Jan 31, 2006 | 08:18 PM
Ok thanks for the help guys, i just want to be sure they will be tight enough
Old Feb 1, 2006 | 11:55 AM
Well if your friends call you Poindexter and you can touch your thumb to your middle finger aroung your biceps, then have your girlfriend do it.
CARiD
Jan 27, 2015 06:27 AM
ModdedNerd
Dec 14, 2014 10:28 AM
Elcojoe
Nov 17, 2014 10:27 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
