Quick Intake Manifold Question
I purchased a new painted and ported Intake manifold on the bottom theres hex head plugs that need to be installed, does anyone know what they should be torqued to? I want to make sure there nice and tight so they don't leak or fall out after installed. Thanks
Re: Quick Intake Manifold Question
I'd say 20 ft. lbs. would be plenty. There should be a heat shield over those hex plugs, so even if they DID fall out, they would be contained. The plugs block off internal EGR passages.
Originally Posted by SStrokerAce
Takes more than 20ft lbs to get them out..... they are a tappered thread I think so just tighten them down hard.
Bret
Bret
Just crank them down good with a ratched. I don't mean to twist them to within an inch of their lives, I mean just crank them down to where it feels "right".
And if it were me, I'd use anti-seize. Lightly.
Just screw them down tight by hand with the allen wrench. If you're worried about them rattling loose, use some non-hardening sealer on the threads. They're not that of a big deal.
CARiD
Jan 27, 2015 06:27 AM
ModdedNerd
Dec 14, 2014 10:28 AM
Jul 4, 2005 05:00 PM
