Quick Intake Gasket question
Old Jan 14, 2008 | 09:26 PM
LenT1's Avatar
I am getting mixed answers on this. I have the how to rebuild an lt1 book and it says to use sealent only around the coolant holes on the intake gaskets that go on the heads and only on the side facing the intake manifold i believe... Anyway how much sealant do I use and exactly what spots on the two gaskets? I know I also need to run a bead around the front and rear of the block if I read correctly... Im ready to seal this bad boy up and get it installed.
Oh yea... I also did not put any sealant on my oil pan gasket...although it was very thick and took quite a bit of trouble to get the pan torqued to spec... Should I untorque everything and start over because I forgot the sealant? I already filled the block with oil too...
Old Jan 14, 2008 | 09:32 PM
mdenz3's Avatar
What coolant holes in an LT1 intake gasket?
Old Jan 14, 2008 | 10:08 PM
LenT1's Avatar
I was confused too? There were no pictures...it said "place sealant around the coolant passages in the intake" did I mis interp it?
Old Jan 14, 2008 | 10:28 PM
mdenz3's Avatar
Either book is for the LT-1 or is plan wrong.
For the LT1 intake gaskets use sealant on the valley walls between them and use the little tabs to keep them on the heads.
Old Jan 14, 2008 | 10:43 PM
truedualws6's Avatar
There are no coolant passages on the intake flange of an LT1 head. The only
sealant is placed along the front and rear sealing edges of the block and you
run the bead approx. 1/2" up on the intake gaskets.
Old Jan 14, 2008 | 10:44 PM
OBE1 95Z28's Avatar
No coolant flows through the LT1 manifold, so as stated above, is the book for the original LT-1 engines from the seventies or the 1990's LT1 engine?
Old Jan 14, 2008 | 10:51 PM
LenT1's Avatar
Ah good question. Don't have it with me but I will have to take a look. You guys answered my question though, thanks!
Jazsun
Dec 29, 2014 12:14 PM
Noenav
Dec 6, 2014 07:35 PM
thenewkid
Nov 27, 2014 09:41 AM
