quick hotcam question
Old Mar 5, 2007 | 05:55 PM
liltxboi911's Avatar
i ordered a LT4 hotcam on ebay for pretty cheap, all the part numbers and everything on the card and the box match up, but the card says the intake/exhaust duration @ .050 is 219/228 but everywhere else i see that sells the hotcam lists it as 218/228, is this right?
Old Mar 5, 2007 | 06:21 PM
Ricardo's Avatar
I remember I found the same when I installed the hotcam in my previous motor.
You should be allright.
By the way, a 2400 stall works great with the hotcam.
RG
Old Mar 5, 2007 | 08:07 PM
just trying to be certain...this is the card and GM paper i recieved with the cam
Old Mar 5, 2007 | 08:55 PM
2000GTP's Avatar
The parts numbers are correct, I wouldn't worry about it.
Old Mar 5, 2007 | 08:58 PM
The Engineer's Avatar
Be sure to install some fresh LT4 valve springs along with the hot-cam (didn't see those in the photos). Also, I see you have the 1.6 RRs which is also a great up-grade. I really liked my hot-cam when I was doing bolt-ons and I'm sure you will like it. I went from 13.40s to 12.60s with the hot-cam.
WD
Old Mar 5, 2007 | 09:02 PM
alright cool, can't wait to get it in!
Old Mar 5, 2007 | 09:05 PM
89TramsAmGTA's Avatar
You lucky dog. You got the super hot cam.
Old Mar 5, 2007 | 09:08 PM
WD
yea they're in the other box, thanks! those are some really good numbers you had too. i ran a 13.5 with my current mods and only made 1 pass before the track closed, so i could have possibly gotten a 13.4 but who knows. i was hoping for at least a 12.9 after the cam but maybe now i can wish for a mid 12 as well
Old Mar 6, 2007 | 08:47 AM
Z-RATED94's Avatar
With a quality stall in the 3200 range, along with a set of 3.73 gears, and a set of stickie tires, no problem.
Old Mar 6, 2007 | 12:42 PM
lt11997's Avatar
My hotcam also said 219/228 on the card, I had to look at it a couple of times to make sure I wasn't seeing things.
Old Mar 6, 2007 | 09:19 PM
yea i've been all worked up on wondering if this is the right thing i ordered too
so...do you guys think its the same one as everyone else has, just printed differently? or maybe its actually is 1º more than normal?
Old Mar 6, 2007 | 09:22 PM
Z-RATED94's Avatar
Iv'e heard of it before. No biggie.
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
InfernalVortex
Jan 17, 2015 09:35 AM
WildRidez
Jan 16, 2015 03:10 PM
