quick help on where hose go please?
Where does the line that comes out of the top of the evap purge solenoid go to on the throttle body?
what does the coolant tube that runs right down the pass. side head go to on the throttle body?
Does anyone have any good picture of the throttle body and all of the lines going to it?
I am putting back together a car I didn't take apart. It is almost done but, I am having a little trouble with all of these lines. I appreciate any help I can get. I'm sure I will have more questions.
Thanks,
Dustin
Thanks,
Dustin
Top of the TB is the PCV hose. Very bottom of the TB is the coolant passage (Radiator-through TB-hardline-back of cylinder heads) hence the famous "TB bypass" which is definitely worth it. Dont remember what the 2nd hose down on the TB is....
68camaroboltz
Oct 5, 2015 11:56 PM
NewsBot
Sep 14, 2015 09:20 AM
