QUICK!!! Help needed(starter removal)
Old May 24, 2003 | 12:51 PM
irocdreamer's Avatar
OK I got the two bolts out, but the Y pipe is in the way, so it won't come out. Y ou guys have said it can be done without messing with the Y pipe. How?
Old May 24, 2003 | 01:53 PM
cmbob67's Avatar
I've puled that starter out a couple times now. It does come out with the Y-Pipe in place, but you gotta spend some time on your back tryin to move it around. If I remember correctly, you need to try and turn it up and out of the small gap between the block and the Y-Pipe ( I hope that makes sense ). Yes, it is a major pain in the patute, but it is possible. Good Luck Bro!!
Old May 24, 2003 | 01:56 PM
96z's Avatar
96z
Dont forget the two wires connected to it also..they are 13 and 8mm if memory serves.
Old May 24, 2003 | 02:34 PM
Dave88LX's Avatar
It'll come out w/ the Y-pipe still in I believe vertically. It's been a while.
Old May 24, 2003 | 02:40 PM
$hawn's Avatar
You will have to un bolt the bracket that the tranny lines are bolted to on the oil pan, and that will allow some movement, also the dust cover needs to come out. The Y pipe can stay in.
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
97SSdude
Dec 31, 2014 07:43 PM
pologreen97z
Dec 2, 2014 10:42 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
