cam+stall= no overdrive
Old May 19, 2003 | 12:04 AM
worak's Avatar
Exclamation cam+stall= no overdrive
guys i need some help! i have an a4 with a xe503 cam and 3000 stall. my car wont shift into overdrive. im running 3200 rpm@ 70mph thats with 3.23 in there. do you guys think its a tuning issue or is it my converter? please give me some ideas, or than this the car is running like a champ.
Old May 19, 2003 | 12:08 AM
GhostZ's Avatar
Is it a non lockup torque converter?
That's what it sounds like if it feels like it isn't locking up....or is the transmission itself just not going into OD?
Old May 19, 2003 | 12:23 AM
worak's Avatar
its a non lock up, basically there is no difference between me driving around in drive or overdrive the car doesnt shift any different
Kain's Avatar
I concur. Does it feel like its normally crusing around on the highway with the stock converter, or does the rpm's jump around alot, and feels like its inbetween neutral and drive?
It could be:
1) You've got a non-lockup converter by mistake.
2) The converter isn't locking up like it should.
3) Something in your tranny went wrong.
Another thing is, if you've got the "performance shift mode" button hooked up on your car, don't use it. I wired mine up, and it wouldn't lockup the converter. I stopped using the shift mode button, it locked up like it should.
Old May 19, 2003 | 12:29 AM
worak's Avatar
guys im all confused now look, heres the part number on the converter tci-243105. i got it from summit they recommended it, but it took 3 of these damn things to even get it to sit in the tranny right. honestly i dont know if its a locking or non locking converter. sounds like a need a locking one correct?
Old May 19, 2003 | 12:32 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
correct, needs to be locking..
Old May 19, 2003 | 12:34 AM
worak's Avatar
it jumps around, i can be driving around at 60 give her a little gas and the rpms jsut shoot up, like its in nuetral (no go).
Old May 19, 2003 | 01:01 AM
TMDZ28's Avatar
happened to me once, and one of my bearing in my tranny was cracked.....
Old May 24, 2003 | 02:23 PM
94ZVert's Avatar
Worak, did you ever figure out what the problem was?
Old May 24, 2003 | 02:45 PM
worak's Avatar
no not yet still has a mind of its own. one time i drive it and its at 2100 rpms another time its at 3200 rpm. its really getting on my nerves. waiting to get a shift kit and programming to see if it helps.
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
BLK1997Z28
May 7, 2015 03:01 PM
jb4xx
Feb 2, 2015 10:00 PM
Z28-CTYHNTR
Jan 20, 2003 03:29 PM
