Quick Help Needed....removing fuel lines on LT1 at the intake on the back
Old Jul 22, 2005 | 06:45 PM
  #16
mr_will's Avatar
Re: Quick Help Needed....removing fuel lines on LT1 at the intake on the back
AN fittings screw on and off instead of that goofy *** connection the stock lines have
they make an adaptor for the stock hardlines on lt1's i think they are -6 for the stock lines i dont remember
i had AN fittings welded onto my fuel rails and running an aftermarket fpr
Old Jul 22, 2005 | 06:51 PM
  #17
mr_will's Avatar
http://crankgoboom.com/fittingsonrails.JPG that is my fuel rails
Old Jul 24, 2005 | 02:41 PM
  #18
meangreen661's Avatar
mabey you are just using the tool wrong. It honestly took 30 seconds to pop both of mine off. Just clamp to tool around the line on the intake side of thoes lines then push the tool up under the rubber rings and that will release the spring keeps the lines from popping off.
I fround this site that has a little section on removing them
http://shbox.com/ci/cam_removal.html
Also be sure to bleed you shrader valve. It u look to the left of the fuel pressure regulator you will see a little cap that looks like on you find on a tire stem of a bicycle. You may not have it on there as min was (guess somebody forgot to put it back on), but you will see what looks like the valve stem where you put air in your tires. Just take a key or something and push the core and this will release all the pressure on the fuel system. Also you may want to take off you gas cap to release the pressure on the system.
Old Jul 24, 2005 | 06:35 PM
  #19
phinger23's Avatar
i gave up on the damn fuel lines, i just yanked out the fuel rail...that made life so much easier.
Jazsun
Dec 29, 2014 12:14 PM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
Absolute Z28
Jul 19, 2002 02:21 PM
