Quick help with dipstick install
Old Feb 28, 2003 | 11:11 AM
twells's Avatar
Exclamation Quick help with dipstick install
allright, i am almost done. i cannot get my dang dipstick to go back in. are their any tips or tricks i should try. it either hits my longtubes or the firewall. please help guys and gals
thomas
cz28members=
Old Feb 28, 2003 | 11:42 AM
MYT30TH's Avatar
I recall having trouble with mine.......and what I had done was cut mine in-half with a tubing cutter, and spliced it back together with some fuel line ( worked-out very well )
Old Feb 28, 2003 | 11:53 AM
Blk94Z28LT1's Avatar
it's tough to get in there. Leave the header loose, so you can move it some. Also use a wire wheel and remove the paint from the bottom of the dipstick, the part that goes into the block. And you will have to bend it some and work it in. Be careful, it will kink!
Also, once you get it in there, put a little sealer around the bottom where it goes in.
Old Feb 28, 2003 | 11:58 AM
slashz28's Avatar
sand it down a bit (the bottom part), oil it up, wiggle it and sliiiiiiddde it in
Old Feb 28, 2003 | 12:23 PM
twells's Avatar
the problem is that the headers are already in and i don't want to take them back out or loosen the bolts. i might just cut the dang thing, but how do i but it back together so that it wont leak?
thomas
Old Feb 28, 2003 | 01:32 PM
DirtyDaveW's Avatar
I cut mine in two places. One just an inch above where it goes into the block and the other about a inch above the bracket. I rejoined the pieces using high temp/pressure B&M transmission cooler tubing and some small band clamps. I can take my dipstick out for plug changes like that <snaps fingers> and put it back w/o any hassle whatsoever. I've had it like this since I put on the long tubes back in 2000. I also did somewhat like Slashz28 did and wirewheeled off all the black paint. Slides in and out quite easily after that.
David K. Wilson
'96 Z28 A3
11.1 @ 121 mph
Nov 18, 2023 07:21 PM
jmadoll
Mar 3, 2015 10:16 AM
alex5366
Feb 17, 2015 09:07 AM
Jan 23, 2015 01:13 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
