Quick Fuel Pressure Question
Old Mar 16, 2005 | 02:16 PM
97WS6SCharged's Avatar
Ok, I've been having a miss/stumble/backfire problem lately. The fuel pump is a month old 255 lph, new plugs, wires are ok, all coils are firing (LTCC). Anyhow, I checked the pressure today and here's what I got.
Key on 38 -40 PSI
Running 40 PSI
Running w/regulator unplugged 43-44 PSI
Now when I started it and it was cold, the pressure was dead on 40 PSI no movement from the needle. As the car warmed up and I revved it a time or two, the needle would start wobbling between 38-42 PSI very rapidly. I'm wondering if this is normal or if I need to look at replacing the regulator.
Old Mar 16, 2005 | 08:53 PM
Re: Quick Fuel Pressure Question
Bump for the night crew.
Old Mar 16, 2005 | 09:01 PM
wb3s94z28's Avatar
The fuel pressure regulator increases absolute fuel pressure as manifold absolute pressure increases with throttle opening. The realative fuel pressure should be constant (about 44psi - 300kPa)
DirtyDaveW
Dec 1, 2016 05:37 PM
Alex Barnes
Jan 24, 2015 10:21 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
