Quick Connect Fuel Lines....
Re: Quick Connect Fuel Lines....
Originally Posted by matLT1
After you snap the fuel lines back on are they still supposed to be able to move back and forth a little?? Thanks
Yeah, they are moving a little but not separating. I pulled on them a little and they didn't come apart (didn't want to pull too hard
Update: I just turned the key to run the pump a few times and there weren't any leaks so I'm assuming its fine.
).Update: I just turned the key to run the pump a few times and there weren't any leaks so I'm assuming its fine.
Jan 23, 2015 01:13 PM
Jul 4, 2005 05:00 PM
