Quick cam lube question!
Old Mar 27, 2004 | 09:33 PM
mkent's Avatar
CompCams did me a good favor and did not send me any cam lube for the install. However, I do have some cam assembly lube here from a different company that sent dad's big-block cam. MUST I use Comp Cams' stuff?
Old Mar 27, 2004 | 10:03 PM
truedualws6's Avatar
Don't use the moly type lube on a hydraulic roller cam.
Just use oil or the GM EOS (engine oil supplement). The
moly lube is for non-roller cams.
Do a search for some more info as this has been
discussed before.
Old Mar 27, 2004 | 10:53 PM
lt1g3n's Avatar
i bought the lube from comp cams, its just break in lube -- dunno if this was good or bad , but comp seemed to think it was good ;/
Old Mar 27, 2004 | 10:58 PM
Kain's Avatar
I used regular old assembly lube from Autozone for my cam. No biggie.
Old Mar 27, 2004 | 11:05 PM
97WS6SCharged's Avatar
For my receint cam swap, I just oiled up the part of the cam that rides the bearings.
Old Mar 27, 2004 | 11:09 PM
ibanez6rg's Avatar
There's a reason why they didn't send you any.
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Hurin
Dec 13, 2014 07:38 PM
Noenav
Dec 6, 2014 07:35 PM
