Quick cam install question...
Old Sep 20, 2007 | 10:38 PM
droptop z's Avatar
Just a quick question about sliding the cam into the engine. Does it need to be set to a certain spot (degreed) or is just installed in any spot. I was just wondering if you could screw it up by not installing it correctly.
Old Sep 20, 2007 | 10:45 PM
When the cam gear is installed, it must be correctly phased to the crank gear. You line up the dots on the faces of the gears.
Old Sep 20, 2007 | 10:46 PM
droptop z's Avatar
Thanks!
Old Sep 20, 2007 | 11:03 PM
LTBlackBird's Avatar
yea, on LT1's its impossible to get it wrong, the cam has a dowel pin that has to go into the timing chain gear, then the gear has to line up with the dot on the crank, if when its all said and done the dowel pin should be at 3 o'clock at TDC if i remember correctly
Jan 23, 2015 01:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
